LabWindows/CVI
Showing results forĀ
Search instead forĀ
Did you mean:Ā
Command passing from client to Server
Dear All,
I have Problem with transferring structure from client to Server…
Big Problem is I am Using Android in client Side, server is windows using cvi5.5 in my source code they used
/* Receives data from client.                                                */
static void CVICALLBACK fnDeferredReceive (void *data)
    ClientInfoPtr   clientInfoPtr = (ClientInfoPtr) data;
    char            dataBuf[256];
    int             bytesRead, dataSize, bytesToRead, tcpErr = 0, iReturn,iTotalByteRxvd=0,i   ;
   unsigned   short uTotal =0,uTotal1=0,index=0;
    //assert (clientInfoPtr->readingData == 1);  //commented by sudhir 26-05-2016
     * Disable library error checking as we are going to read until
     * there is no more data left (read call times out).
    //DisableBreakOnLibraryErrors ();
      	/* Read the Request. */
      	  	dataSize = bytesToRead = TDP.uPacketSize;
		dataSize = bytesToRead = 200;
      	while (bytesToRead > 0)
      	iReturn =ServerTCPRead  (clientInfoPtr->handle, &TDP.bSendRequestedData,
		    sizeof (TDP.bSendRequestedData), 50);//was   10000
in Above code they used ASSERT so its giving problem while
in Cleint side (android side) he will send multiple tcpwrite example
tcpwrite1
tcpwrite2
so in server side its giving eror..so I commented assert  so now my progrmm is working but evry time I will get error messge and if he not sending any commad also still evry time my fndefferdrxv will excute pls help me
Message 1 of 19
(5,269 Views)
Which error are you receving? Can we see the code where you call that deferred function?
Message 2 of 19
(5,266 Views)
    char            dataBuf[256];
   unsigned short read_total ;//sudhir
		read_total=0;
      	while (read_total <200)
      	iReturn =ServerTCPRead  (clientInfoPtr->handle, &TDP.bSendRequestedData,sizeof (TDP.bSendRequestedData), 50000);//was   10000
		iTotalByteRxvd=iTotalByteRxvd+iReturn;
		tcpChk(iReturn);
For this code iam getting
Erro
ServertcpLbrary Eror
messge :timeouteror
Sytem eror:no Eror
Iam Not sending any Clenttcpwrt   from Clinet(my clinet is android)still fnDeferredReceive inside my flow is coming
Message 3 of 19
(5,265 Views)
fnDeferredReceive callling from this below code
/* TCP callback function for the server.                                     */
static int CVICALLBACK fnServerTCPCallback (unsigned int handle, int xType,
                                       int errCode, void *cbData)
	static int i = 0;
    if (xType == TCP_CONNECT)
	    /* Connect new client.  */
	    fnConnectClient (handle);
	     bDAQClientReqMade = TRUE;
    else if (xType == TCP_DISCONNECT)
	    /* Client is disconnecting. Update program state.  */
	    DisconnectClient (handle);
    else if (xType == TCP_DATAREADY)
        ClientInfo      clientInfo = {0};
        ClientInfoPtr   clientInfoPtr = &clientInfo;
        int             index;
        /* Find the client information from TCP conversation handle.*/
        clientInfoPtr->handle = handle;
        index = ListFindItem (gClientList, &clientInfoPtr,
            FRONT_OF_LIST, fnCompareClientInfoPtr);
		clientInfoPtr->readingData = 0;
        if (index > 0)
            /* Get the stored client information. */
            ListGetItem (gClientList, &clientInfoPtr, index);
             * NOTE - Because the reading is done in the worker thread,
             * this thread (the main thread) is not blocked, and will
             * continue to receive TCP_DATAREADY events, until all the
             * data is read. This program uses the readingData flag to
             * ignore these events, until all the data is read by the
             * worker thread.*/
			//i = clientInfoPtr->readingData = 0;
            if (clientInfoPtr->readingData == 0)
                clientInfoPtr->readingData = 1;
                PostDeferredCallToThread (fnDeferredReceive, clientInfoPtr,
                   clientInfoPtr->threadId);
    return 0;
Message 4 of 19
(5,266 Views)
It seems to me that the problem lies in ClientInfo and ClientInfoPtr variables being passed to the deferred callback. You must keep in mind that deferred callbacks are execute after the calling function terminates: at this moment, all variables local to the calling function (like your ClientInfo and ClientInfoPtr) are cleared and the pointer received by the deferred callback no longer points to a valid structure in memory. When the deferred callback executes, it points to a invalid memory block, so the handle you retrieve does not refers to an actual TCP connection and you get the timeout error.
If you want to maintain your program structure you could dynamically allocate the memory with malloc inside the calling function, pass the pointer to the deferred callback and free it there: I have already handled some applications with this paradigm with success, if properly configured no memory leak can occurr.
Message 5 of 19
(5,260 Views)
for this i need your help sir
Message 6 of 19
(5,234 Views)
Something along this line.
The calling function (TCP callback):
	ClientInfo      *cI = NULL;
	cI = malloc (sizeof (ClientInfo));
	if (xs == NULL) {				// Out of memory
		// Properly handle this error!
	else {
		memset (&cI, 0, sizeof (ClientInfo));
		cI->handle = handle;
		// Fill all necessary structure field
		PostDeferredCallToThread (fnDeferredReceive, (void *)cI,
			clientInfo->threadId);
		// DO NOT dispose of the dynamic memory!
	return 0;
The deferred function:
static void CVICALLBACK fnDeferredReceive (void *callbackData)
	int			error = 0;
	ClientInfo	*cI = 0;
	if (!callbackData) {
		error = 1;
		goto Error;
	cI = (ClientInfo *)callbackData;
	// Handle data content
Error:
	if (cI) free (cI);		// Free dynamic memory
	if (error) {
		// Handle errors in the function
	return;
Message 7 of 19
(5,230 Views)
okay I wil try this
Message 8 of 19
(5,227 Views)
this line giiving eror saying tht cI Argument too small
Message 9 of 19
(5,207 Views)
The deferred call back ques is ful msg error is coming for this code
	static int i = 0;
	ClientInfo      *cI = NULL;//sudhir
	 cI = malloc (sizeof (ClientInfo));//sudhir
       	//ClientInfo      cI = &clientInfo;
        int             index;
        memset (cI, 0, sizeof (ClientInfo));
		PostDeferredCallToThread (fnDeferredReceive, (void *)cI,cI->threadId);
    return 0;
//static void CVICALLBACK fnDeferredReceive (void *data) //commented by sudhir
	char            dataBuf[256];
	int			error = 0;
	ClientInfo	*cI = 0;
				error = 1;
		goto Error;
    //ClientInfoPtr   clientInfoPtr = (ClientInfoPtr) data;
   cI->readingData = 1;
   // assert (clientInfoPtr->readingData == 1);  //commented by sudhir 26-05-2016
		read_total=0;
      	//aft delete test sudhir------------------
      	iReturn =ServerTCPRead  (cI->handle, &TDP.bSendRequestedData,sizeof (TDP.bSendRequestedData), 50000);//was   10000
Message 10 of 19
(5,208 Views)
