11-27-2010 07:36 AM
1. To get value of panel element we need use function GetCrtlVal (PH, P_ELEMENT, &val).
Return value - int only, indicator of error.
What command-analog you know? I want to do that:
val=analog_getctrl_val(...)
(call) func(val).
or (call) func(analog_getctrl_val(...)).
2. Other little questions:
- if i have path "C:\111\222\333\444" - i know, how get the left part "/" ("C:\). How with one function get right path ("444")?
- how add to string integer? Have a string "Added", integer "1000" and string "files". How implode that in 1 string? Can i do this implosion in function arguments?
(call) func(string "string + int + string")?
- in VB command "xxx mod 100" - means "if xxx divide to 100". How write that in CVI?
11-28-2010 01:15 PM
A1. GetCtrlVal returns the value read in the third parameter, the one you pass by reference, There is no other way to use that command. The correct usage is:
GetCtrlVal (panelHandle, PANEL_CONTROLID, &val);
func (val);
Your alternatives cannot be implemented with native commands.
A2.
1. I suggest you to study SplitPath () command.
2. You cannot build a string like in VB: use sprintf instead.
sprintf (destinationString, "%s %d %s", "Added", 1000, "files");
func (destinationString);
3. In VB mod returns the remainder of a division. To implement this in CVI you can use either fmod () command (for doubles) or the remainder opeator "%" (for integers)
