LabWindows/CVI
取消
显示结果
搜索替代
您的意思是:
Child panel -how to put him at specific place in Parent panel
已解决!
转到解答
Since a tab page is its own panel, you can enable the panel scroll bars...
GetPanelHandleFromTabPage(panelHandle, PANEL_TAB, 0, &tabPanel);
SetPanelAttribute(tabPanel, ATTR_SCROLL_BARS, VAL_VERT_SCROLL_BAR);
11 条消息(共 13 条)
1,230 次查看
Gosh! So simple it was! There are so few attributes that cannot be set in the UIR editor that I didn't even thought about setting it programmatically!
Thanks jared for this tip
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
0 项奖励
12 条消息(共 13 条)
1,225 次查看
Thank you for  completing the solution it was helpful.
Last weak i haven't been at work , so only today i saw the comments.
Thank you all.
0 项奖励
13 条消息(共 13 条)
1,175 次查看
