LabWindows/CVI
Check if TCP client connection failed
I am using tcp/ip server client protocol using in my project...and its working fine,but some time my client will hang how to detect  error in Server.
Thank you in Advance
(4,267 Views)
On one side you can ping the server IP to detect wether it is responsive. You can set a short timeout for InetPing so that your app is not handicapped.
On the other hand, you must manage TCP_DISCONNECT event in the client callback and take the appropriate countermeasures if it fires.
Once made this, the server usually have no other troubles, but  I suggest you to record all abnormal event you get together with any detail available, including runtime errors and function on error.
(4,261 Views)
