LabWindows/CVI
Change text color of individual table cell using Word Report
I am using LabWindows/CVI version 8.0.1.
I started a Word application and opened an existing Word document using:
RESULT = WordRpt_ApplicationNew (VTRUE, &WORD_APP_HANDLE); // Open word application
RESULT = WordRpt_DocumentOpen (WORD_APP_HANDLE, "C:\\TEST_FILE.docx", &TEST_FILE_HANDLE); // Open report file
I then added a 2 row, 6 column table to my report file using (all text I put in the table is the default color of black):
RESULT = WordRpt_AddTable (TEST_FILE_HANDLE, 2, 6, &TABLE_HANDLE); // Add table
By adding a "SetTextAttribute" line before the table is created, I changed the color of all text in the table to blue
RESULT = WordRpt_SetTextAttribute (TEST_FILE_HANDLE, WR_ATTR_TEXT_COLOR, WRConst_Blue); // Set text to blue
By creating the table one row at a time, I can have each row another color:
RESULT = WordRpt_AddTable (TEST_FILE_HANDLE, 1, 6, &TABLE_HANDLE); // Add table
RESULT = WordRpt_SetTextAttribute (TEST_FILE_HANDLE, WR_ATTR_TEXT_COLOR, WRConst_Green); // Set text to green
However, once set, I am not able change the color of a row nor am I able to have each column a different color text.
Does anyone know the coding to be able to build a table in a Word document where I can have individual cells in a table any color I want?
As another issue, I am also looking for coding to change the font of various table cells to bold.
Message 1 of 1
(1,207 Views)
