LabWindows/CVI
Cannot locate entry point in msvcrt.dll
When installing my program (created with LabWindows 'Build Distribution') on a specific computer I get the following error:
"The procedure entry point_except_handler4_common could not be located in the dynamic link library msvcrt.dll"
I understand this is usually due to an older dll being on the installation computer as compared to the dll it was linked with, and I verified that is the case.
The target computer is current on all updates, but the target computer is Windows XP, while the development computer is Windows 7.  I have not had issues with this configuration with other programs, but perhaps the other programs were not looking for this entry point.   The installation has installed successfully on other Windows 7 machines.
Any ideas?
Thanks!
Angie
(6,206 Views)
Hi Angie,
Is there an error code associated with the message you are seeing?  Would you mind posting a screen shot of the error dialog?
A few more questions -- what version of CVI are you using?  Are you including the run-time engine in your build?  Does your target machine have CVI already installed on it -- and if so, what version?
Thanks!
Stephanie R.
Stephanie R.
(6,184 Views)
(6,165 Views)
Accepted by AMM
Something to check is to make sure that the distribution kit is not including Windows System files in the distribution kit from the development PC.  It can do this if you have libraries in your project from the Windows SDK or DDK (like ShFolder.lib).  When this happens the software will generally install and run fine on a computer running the same Windows version as the development machine but all kinds of problems happen when you try installing on another version.
(6,158 Views)
I'm having the exact same issue when launching the 2015 Driver Station (labview 2014 for FRC).
I try understanding the solution but honestly failed.
Actually I get additional error windows.  I beliueve I have them all in the screen garb below.
(4,695 Views)
There's actually a separate forum for the FIRST robotics competition. You should post this question there, and it will be seen and addressed faster by our engineers 🙂
https://decibel.ni.com/content/community/academic/student_competitions/frc?view=discussions
Kristen M
Automated Test Product Marketing Engineer
(4,672 Views)
