LabWindows/CVI
Can't call function from dll or lib file
I am trying to call c++ function SendCANMessage from .lib file into my CVI project by following steps from this link:
Link (Part: 2nd way to use a DLL).
I have included 2 .h and 2 .c++ files into DLL project in Visual Studio, added __declspec(dllexport) in front of functions that I want to use in CVI
and built project successfully. Then I have added .lib and .dll files that I got from this build into my CVI project. and tried to call one of functions from .c file (from CVI). When i build project, it says:
Function declaration in .h file is: CAN_ERROR SendCANMessage(CAN_msg *pMsg, DWORD dwTimeout); and I have
defined CAN_ERROR, CAN_msg and DWORD earlier in my .c file.
I found that -10 means this: "Identifier not defined globally in the module.", but i don't know what to do about it.
I think that CVI don't see any of functions in .lib and .dll files and i need help how to include it properly, because I just added
these files by Edit->Add Files To Project and added files. I provided archive with all files that are included in CVI project.
Igor
(3,819 Views)
Are you sure you create the DLL and lib file in Visual C as the same bitness than what you run in LabWindows/CVI?
Rolf Kalbermatter  My Blog
(3,793 Views)
Make sure that the functions exported from the VC dll are C-style functions.
See http://www.ni.com/white-paper/3341/en/#toc9 for details.
Also, why don't you use the 1st part in the document you linked? It is easier.
(3,763 Views)
Accepted by bigor94
Thank you for your answers,
the problem was that I have generated bad dll and lib files.
I couldn't include extern "C" in front of functions because that functions are members of class and I got linkage error, so I needed new .h file
where I have put all definitions from two header files (RT_COM.h and RT_CAN.h) and wrap it with extern "C" {}. Also I have added declarations of functions with extern "C" __declspec(dllexport) in front of them. When I built this in VS i got new dll and lib files, copied dll, lib and h files to CVI project folder, added lib to project and included h file in my c file. Example of usage this c++ functions in c program is shown bellow:Capture.JPG
You can see .h file in attachment.
(3,756 Views)
