LabWindows/CVI
Callback function for label appearance.
Is any option to access the label using Callback function.
Message 1 of 8
(3,977 Views)
Maybe you can provide a few more details:
- you want a callback called if someone clicks on a label
or
- you want to change the label once someone clicks on the associated control
or
Message 2 of 8
(3,971 Views)
If i take edit command button, only if command button is clicked leads to callback but if label is clicked it wont . I wanted the operation even if label is clicked
Message 3 of 8
(3,966 Views)
I am afraid I do not understand... for a command button the label is on the button, so how can you click on the label without clicking on the button?
I am attaching a typical screenshot
Message 4 of 8
(3,947 Views)
Is any option if  I click on label instead on button ??
Message 5 of 8
(3,945 Views)
.... how can you click on the label without clicking on the button if the label is on the button?
Message 6 of 8
(3,938 Views)
a possibility to have a "clickable" label is
- do not use a label for your control
- use a text message instead which provides its own callback function
Message 7 of 8
(3,935 Views)
Thanks even 'm using the same but I thought is any option for label too
Message 8 of 8
(3,906 Views)
