I am trying to do deploy a code to a realtime Target from CVI, but getting some DLL errors. Before going to the details, here are the system details
- Windows 7 Desktop PC (64bit OS)
- NI Reatime 15 installed on PXI reatime target
- LabWindows/CVI 2015 on Desktop pc
- Microsoft visual c++ redistributable and run time components are installed on the pc
When attempting to deploy the code the following error messages were shown.
after clicking continue in the above dialog, following error appears.
The error on build output says "MSVCP100.dll (also MSVCR100.dll) cannot be copied to target because it could not be found"
if trying to use some daqmx functions, the following error also appears.
I have verified that MSVCP100.dll, MSVCR100.dll and nicaiu,dll are present in the Windows/System32 folder.
what could be the problem? The RT system is fine though when simple codes are deployed.
Waiting For the inner calling
