LabWindows/CVI
CVI OGL requires parent panel while easy tab only allows child
I am having a problem where I am using the easy tab control to load panels
and this library only accepts Child panels to load into easy tab create.
In some of the tab menus I wish to create a graph using OGLConvertCtrl
to convert a picture to an OGL control, but this function only accepts
parent panels. I have read other posts that deal with OGL parent panel
limitatoin by using windows function Setpanel. I have opened the panel
as a parent panel and then used SetParent to make it a child of the main
panel passed into easy tab create, but the easy tab create function still
recognizes it as a parent panel and not a child of the main panel.
Is there another way to enable me to use both the eay tab control and
OGL controls, or something else I can try?
(2,891 Views)
See comments on the following post.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(2,874 Views)
