01-31-2012 11:23 AM
I have an installation error 2753. Indicating a problem with NIDNS NSPTool.exe.MDNSOI. I have done some searching but have not turned up a fix. I have installed CVI 2009 successfully and failed the install of NI Device Drivers Nov 2009. The install continued with out any further problems. I then retried the install and received the same error. I continued and installed NI DAQ 9.0.2. This completed successfully. Is this error critical ? What can I do to fix this ?
01-31-2012 03:20 PM
It's hard to tell specifically. What NI Software did you have installed prior to this? Have you uninstalled or repaired in the past? What OS are you using?
A couple things to try.
I will probably be able to identify from the log, but in case not, at what point during the installation process does the error appear?
01-31-2012 04:08 PM
I am having trouble launching the setup.exe
In the cmd window I have typed f:\setup.exe /log C:\setupLog.txt
I receive this error.
.\UberInstaller.cpp(1681): IInstallerError 10009
Fatal Error. Unable to create temporary file.
Unable to copy original f:\SupportFiles\resourceEng.dll to C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\nii22.tmp.
Windows Error Windows Error 87: The parameter is incorrect.
I have tried several locations to save the text file.
None of them work.
I checked in c:\Documents and settings\administrator\local settings\temp\ there is no nii22.tmp
02-01-2012 03:12 PM - edited 02-01-2012 03:15 PM
The additional information you asked for is:
Pentium 4 3 Ghz
504mb ram
XP V2002 SP2
No NI software previously installed ((That I am Aware of))
I work in an office of engineers. anything is possible.
No evidence of NI in the "add-remove" programs.
02-01-2012 03:56 PM
Rich,
In the past when this error has come up, it has been related to a bad CD (manufacturing defect). Is the problem just with the driver CD, or is it with the CVI CD? If it is the CVI CD, then I can send you a new copy of the CD (or a digital copy) to see if that resolves the issue (Private message me your contact information). If this is just the driver CD, then I can also send you a replacement, but it may just be simpler to download the drivers you need from ni.com/drivers. Though it sounds like DAQmx installed fine the first time. It may be worthwhile to download the driver and then do a repair on the installation.
02-01-2012 04:06 PM
I am not familiar with messageing "in Private" How is this done ?
02-01-2012 04:15 PM
If you click on my name here in my post and go to my profile, there is a blue link labeled "Send this user a private message". In any case, I will send you one that you can reply to now.
