LabWindows/CVI
CVI 5.0.1p4 bug?
I've got a program that fails on machines with 5.0.1p4 installed,
and succeeds on machines without 5.0.1p4 installed. Any ideas on
what the problem may be?
The error message is:
Error in call to LoadPanel
Parent Panel Handle = 0
UIR Filename = "Brewer.UIR"
Panel Resource ID = 10
Error code -90
"The attribute value passed is not valid"
The header, UIR, and source that use them are all in the same
directory. Recompiling the software does not appear to change
the error.
Any help will be greatly appreciated!
Message 1 of 1
(2,588 Views)
