LabWindows/CVI
CVI 2017, strange behaviour in code editor.
I hope I'm not the only one experiencing a weird behavior in the freshly installed LabWindows/CVI 2017 editor window, on two different PCs.
When I delete a line, and move the cursor down the subsequent lines disappear, and then reappear with a very disappointing effect.
An image is better than thousand words, so here it is an animation that shows it. Here I moved only a single line the cursor down.
It get worse when you're in a hurry and move down the cursor down more than once:
Carlo A.
Megaris
Message 1 of 22
(6,001 Views)
...and I thought CVI2017 has few new features only Smiley Very Happy
Seriously, I just tried it and can't confirm this observation - how large is your file? I've tried it with a file of 30000 lines and everything seems fine. Somehow your description sounds as if your PC is very busy with other tasks, e.g., virus scanning... but both PCs, hm...
What are your Editor Preferences?
Message 2 of 22
(5,988 Views)
Wolfgang, I'm happy to hear. Both PCs are absolutely unloaded.
CPU i7 3.5 GHz, 16giga RAM, SSD, Windows 10 pro fully updated, antivirus (defender) disabled.
I will investigate further...
The file you see in animated GIFs has only 375 lines.
Carlo A.
Megaris
Message 3 of 22
(5,987 Views)
@Wolfgang I tried on an absolutely new PC, first program installed LabWindows/CVI 2017. All settings at their defaults, no other programs except the standard bloatware coming with Windows 10.
Same problem.
I discovered it happens only in "row selection mode" (Ctrl+Ins change it)Untitled.png
This may explain why you didn't notice it.
Steps to reproduce:
1) Create an empty source file
2) ensure you are in row selection mode.
3) write some text rows, ideally numbered from 1 to say ... 10
4) select a single row, let's say row number 4, moving cursor up with cursor keys and pressing once shift+ cursor down
5) Hit "Del" key
6) Row 4 disappears, as wanted, AND Row 6 too!
7) Wait a second or about, row 6 reappears.
If you don't wait and instead you move cursor down, you can have the strange effect of rows disappearing and reappearing, with a weird "scroll down" effect.
If you select TWO rows at step 4) nothing strange happens.
I have not found any workaround.
Carlo A.
Megaris
Message 4 of 22
(5,951 Views)
AH, now I can also see it.
The bad news: your observation seems not correct... after switching back to my standard character selection mode it also occurs in this mode Smiley Frustrated and I have not found a way to avoid this "double update"
BUT it seems specific to the project: If I load another project (*.cws) character selection mode works fine - but switching back to my original project does not help, something has permanently changed Smiley Surprised
So if I would have plenty of time I could get my backup copy and compare if / what line in the cws / prj file has changed...
Some assistance by NI would be welcome, this behavior is annoying...
Message 5 of 22
(5,949 Views)
I tried both with a brand new prj/cws and with an existing project. The bad behavior occurs as I told you previously, only with "full row selection mode". May be there is some other implication or prerequisite.
At present I have very little time to do more testing.
I just checked that 2017 beta (build 230) had already this problem and I didn't notice it.
I admit I've tested only the build process compiler and general performance of compiled programs, but I haven't spent time doing any relevant editing with that version. A lesson for next time.Smiley Sad
I hope that a workaround will be found soon...
Carlo A.
Megaris
Message 6 of 22
(5,943 Views)
I have just obtained yesterdays backup - now I have two different cws files for the same project. Using yesterdays version works fine, the one of today (after cycling through the row selection mode in CVI2017) shows the problem.
Message 7 of 22
(5,933 Views)
Now I'm curious, could you please send me - privately of course - the two CWS files ?
Carlo A.
Megaris
Message 8 of 22
(5,928 Views)
It is too strange... I spent quite some time hunting this bug because suddenly it was gone, then it reappeared..., renaming the cws file did something sometimes....
Also this effect seems to depend on the editing history: if I open the file and the first action is deletion it may work while if I do some other editing before it may not work.
So I have situations where all scenarios work fine, i.e., whatever the row selection mode, and I could get situations where both row selection modes showed your problem... Smiley Frustrated Smiley Frustrated Smiley Frustrated
So now I will PM you the files but will stop further investigations...
Message 9 of 22
(5,921 Views)
I've noticed the same cross-effects of who-knows-what.
If this is the situation, I'll too give up.
I hope that some nice guy from NI will show up here and at least he will acknowledge the problem.
Carlo A.
Megaris
Message 10 of 22
(5,919 Views)
