LabWindows/CVI
CVI 2009 find command
Not sure if this is a bug or some new setting I'm missing, but in older version 'find' used to save the last settings used and 2009 doesn't seem to save them.  I've checked the "multiple files... " option, but it's not checked on the next use of the find command.
(3,200 Views)
Accepted by gtoph
The behavior has changed slightly. Now there are two separate keyboard shortcuts for "Find" and "Find in Files". When using Ctrl+F (the default shortcut for "Find") "multiple files..." will always be unchecked. If you instead use Ctrl+Shift+F, multiple files will be checked, and the your settings should be preserved.
Hope this clears things up.
Mert A.
(3,190 Views)
Ahh gotcha... should have figured something like that.
(3,186 Views)
