LabWindows/CVI
Byte swapping float variables
How can I byte swap a four byte float variable using the format modifiers supplied with CVI?.
Message 1 of 9
(7,319 Views)
The following are snippets from the NI LabWindows/CVI Help files included with CVI. I would recommend accessing the document by going to Help->Contents and doing a search for 'Format'. Click on 'Formatting Functions' in the Search Results box.
Here is the general layout of the �Fmt� function that CVI supplies.
n = Fmt (target, formatstring, source1, ..., sourcen);
�formatstring� has the following form: "target_spec < source_specs_and_literals"
% [ rep ] formatcode [[ modifiers ]]
The character '%' introduces all format specifiers. rep indicates how many times the format repeats with respect to the arguments. formatcode is a code character that indicates the nature of the data items you want to format. Modifiers is an optional, bracket-enclosed sequence of c
odes that further describes the data format.
Here is an example from the help files:
�if a GPIB instrument sends 2-byte binary data in Intel byte order, the code appears as follows:
short int instr_buf[100];
short int prog_buf[100];
status = ibrd (ud, instr_buf, 200);
Fmt (prog_buf, "%100d<%100d[b2o01]", instr_buf);
If, instead, the GPIB instrument sends two-byte binary data in Motorola byte order, Fmt appears as follows:
Fmt (prog_buf, "%100d<%100d[b2o10]", instr_buf);
In either case, you use the o modifier only on the buffer that contains the raw data from the instrument (instr_buf). LabWindows/CVI ensures that the program buffer (prog_buf) is in the proper byte order for the host processor.
The format modifier for 32 and 16 bit Intel is [o0123]and [o01] and [o3210] and [o10] for Motorola byte order.
If you need further assistance please post back. Good luck!
Craig H.
Message 2 of 9
(7,319 Views)
There is one thing to watch out for here, The "o" operator for the Fmt function does not operate directly in floting point datatypes; you need to you need to put your floating point data ina holder int in order to be able to use the Fmt.
Here is a small piece of code on how to do this:
#include
#include
int main (int argc, char *argv[])
float f=0.12358445685687967896796780870890;
void *i;
int a;
i = &f; //copy the bytes on the float to an int
a = *((int *)i);
//print the float
printf("\nThe value is: %f", *((float*)i));
//show how the float data looks as an int
FmtOut("\nThe Floating point read as an int is: %d", a);
//Swap the byte order
Scan(&a, "%i[b4]>%i[b4o3210]", &a
printf("\nThe Swaped int is: %d", a);
//return the float to it's original location
i = &a;
f = *((float *)i);
printf("\nThe swaped float is: %f", f);
getchar();
return 0;
I hope this helps.
Juan Carlos
N.I.
Message 3 of 9
(7,319 Views)
Hi Craig,
Many thanks for the reply. Yes I did know about the integer byte swaps but applying the "o" format modifier is illegal when applied to a float. Maybe this function could be added to the next version release for CVI?.
Cheeerio
Mike
Message 4 of 9
(7,319 Views)
Hi Juan Carlos,
Many thanks for your reply. Brilliant!!. How did you ever think of that!. Is there a way of byte swapping 8 byte doubles?.
Maybe NI could put a format modifier to byte swap floats and doubles like integers in the next CVI version release.
Cheerio
Mike
Message 5 of 9
(7,319 Views)
If you are using CVI 7.0 you can use a 64 bit integer, must operations are now supported. You can declare a 64 bit integer as __int64 (double underscore at the beginning) than use the same procedure that I posted before.
I would appreciate if you post your suggestion for CVI by going to http://www.ni.com/contact ans selecting prodect feedback; our developers monitor those suggestions.
Good luck with your project.
Juan Carlos
Message 6 of 9
(7,319 Views)
This sample code from the help file results in a "Parameter type incompatible with format specifier".  The problem is the specifier "i" assumes 4-byte normal integers.  So a modifier of [b2] must be used. Here's the correct code:
short int instr_buf[10] = {1234, 9421, 0x279, 0}; // sample data
short int prog_buf[10] = {0};
Fmt(prog_buf, "%10i[b2]<%10i[b2o10]", instr_buf);
Message 7 of 9
(6,557 Views)
Or you can do it manually using a union...
Using the union you can manipulate the bytes any way you want.
union UNION_4_BYTES
   float          f32;
   int            i32;
   unsigned int   u32;
   int            en;    // enum type
   short          s16[2];
   unsigned char  byte[4];
union UNION_4_BYTES source32bitNum, target32binNum;
source32bitNum.i32 = 123;
target32bitNum.byte[0] = source32bitNum.byte[3];
target32bitNum.byte[1] = source32bitNum.byte[2];
target32bitNum.byte[2] = source32bitNum.byte[1];
target32bitNum.byte[3] = source32bitNum.byte[0];
// your target byte swapped value is in target32bitNum.i32
Message 8 of 9
(6,554 Views)
I don't understand all those specifiers in the Fmt and Scan commands.  I would just do it the old-fashioned way:
int* i = (int*)&myFloat;
*i = ((*i & 0xff000000) >> 24) |
     ((*i & 0x00ff0000) >> 8)  |
     ((*i & 0x0000ff00) << 8)  |
     ((*i & 0x000000ff) << 24);
Message 9 of 9
(6,536 Views)
