LabWindows/CVI
Avoid General Protection Fault
How can I prevent the pop-up message of General Protection Fault, when using XML functions?
For example: errChk(CVIXMLGetRootElement(ReportHandle, &ReportRootElement))
When the ReportHandle is not correct I receive the General Protection Fault message.
Is there any way to prevent the message?
I tried: DisableBreakOnLibraryErrors(), SetBreakOnProtectionErrors(0) functions, but without success.
Thank you.
(3,548 Views)
Several aspects to this :
1.  There's no way I know of the trap and handle a GPF in CVI.  You just have to not generate them in the first place 🙂
2.  You can set a registry value to not do popup error messages (error mode) and to not send a love note to micro$oft but if you GPF you're process is going to die anyway.
3.  These are Win32 errors, not a CVI library error per se though the issue may be with the CVI library.   So the library error management functions don't do anything for you here.
I think you need to check for a valid report handle prior to making the call.
Menchar
(3,528 Views)
Thanks, I will check for a valid report handle.
(3,500 Views)
