01-22-2009 08:14 AM
How can I prevent the pop-up message of General Protection Fault, when using XML functions?
For example: errChk(CVIXMLGetRootElement(ReportHandle, &ReportRootElement))
When the ReportHandle is not correct I receive the General Protection Fault message.
Is there any way to prevent the message?
I tried: DisableBreakOnLibraryErrors(), SetBreakOnProtectionErrors(0) functions, but without success.
Thank you.
01-23-2009 12:05 AM
Several aspects to this :
1. There's no way I know of the trap and handle a GPF in CVI. You just have to not generate them in the first place 🙂
2. You can set a registry value to not do popup error messages (error mode) and to not send a love note to micro$oft but if you GPF you're process is going to die anyway.
3. These are Win32 errors, not a CVI library error per se though the issue may be with the CVI library. So the library error management functions don't do anything for you here.
I think you need to check for a valid report handle prior to making the call.
Menchar
01-24-2009 11:40 PM
