08-28-2008 05:23 PM
I have a need to recover frequency and level information from a PCM stream that has been written to a file.
The PCM data is 16-bit signed, little-endian, sampled at 8Khz.
What CVI functions (if any) can be used for such a task?
Brian
09-11-2008 10:18 AM
Hi Brian,
To my knowledge there are no specific CVI functions that will accomplish this.
09-12-2008 03:38 AM
You should be able to read in the data portion of the file (skipping over any header such as may accompany a .wav file) into an array and then submit it to functions in the Advanced Analysis Library (you need the FDS version of CVI for these). PowerFrequencyEstimate() is just one of a number of functions you might find useful.
JR
