LabWindows/CVI
Add Item in Ring durch Programm
I need to add some Items to an Popup Menu Ring  control via my Programm.
I can't find the right Val or Attribute to set this.
Thanks for Help
(3,518 Views)
maybe InsertListItem (, , , "", );
(3,515 Views)
Item in a popup menu ring -the same as in other ring controls- are inserted using InsertListItem () function; use ReplaceListItem () to change an item in the list. You can also remove items using  DeleteListItem ()
(3,514 Views)
it works.
(3,509 Views)
