LabWindows/CVI
Showing results forĀ
Search instead forĀ
Did you mean:Ā
Add Item in Ring durch Programm
I need to add some Items to an Popup Menu Ring  control via my Programm.
I can't find the right Val or Attribute to set this.
Thanks for Help
(3,455 Views)
maybe InsertListItem (, , , "", );
(3,452 Views)
Item in a popup menu ring -the same as in other ring controls- are inserted using InsertListItem () function; use ReplaceListItem () to change an item in the list. You can also remove items using  DeleteListItem ()
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(3,451 Views)
it works.
(3,446 Views)
