LabWindows/CVI
Hi I am using NI6509 to drive a hardware using the codes below but I did not get the expected output. Is there anything wrong on the way I configure the port?
DAQmxErrChk (DAQmxCreateTask("",&DIOHandle));
DAQmxErrChk (DAQmxCreateDOChan(DIOHandle,"NI6509/port3/line0:4, NI6509/port0/line2:0, NI6509/port0/line5:3","",DAQmx_Val_ChanForAllLines));
(3,682 Views)
Hi JSYow,
Is it possible for you to attach your VI here? If not, can you give more detail of you application, the expected outputa and the output you get?
Thank you,
Rufan Mo
Certified LabVIEW Associate Developer
(3,649 Views)
