LabWindows/CVI
xdimax sub-20
i need to work with Xdimax sub-20 board.
Does anyone can point me to an example CVI code?
What needs to be included in the project to successfully communicate with this board?
I need to use the SPI portion of it.
Thank you,
Alex
ALH
(3,829 Views)
Hi Alex,
 I found some drivers for the Xdimax sub-20 board. They might be a good starting point even if they aren't exactly pertinent to your application. Also, they might have relevant examples that could help. I also wanted to confirm that this is the product you were referring to since the term xdimax shows up a few different things. Feel free to reply if you have anymore questions or clarifications.
Xdimax sub-20 board:
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=16050
Best,
Ali S.
Ali S.
Applications Engineering
(3,807 Views)
Thank you Ali,
Your link brings up the SUB-20 LabView driver.
I'm working with LabWindows/CVI.
The board I'm referring to is this: http://www.xdimax.com/sub20/sub20.html
Thank you,
Alex
ALH
(3,787 Views)
