LabWindows/CVI User Group Discussions
How Can I Use DLLs Created in LabWindows/CVI with Visual C++?
I want to create a DLL in LabWindows/CVI and then use it with Visual C++.There is no any problem if CVI and VC++ are on the same computer.But my VC++ is on another computer witch has never installed CVI before.There is no problem with compile and link when I use the DLL created in CVI with VC++,but error occurred as shown is figure 1 when running.I think it is because there is no CVI Run-Time Engine.
Q:What should I do then? Whether the CVI Run-Time Engine could be loaded into the DLL, which is more convenient to use with the DLL? (except installing CVI Run-Time Engine manually)
                                             Figure 1 Error Information
                                         Figure 2 My "Target Settings"Dialog
(6,521 Views)
Hi chzt,
The LabWindows/CVI runtime is a dependency of your LabWindows/CVI-built DLL. It must be present on the  system where you are using your DLL. Please see http://zone.ni.com/reference/en-XX/help/370051AC-01/cvi/programmerref/cvirtengine/ for more information about the runtime.
Daniel Dorroh
(6,072 Views)
Thanks.
(6,072 Views)
