zoom a picture
I'd like to be able to allow a user to zoom in and out of a picture displayed on a labview front panel. Is this sort of thing only possible with IMAQ? Is there a relatively simple example available that demonstrates how to do this?
Message 1 of 10
(9,153 Views)
Hello
It is nor clear what type of picture are you talking about.
Perhaps you should look at ../examples/picture/demos.llb and pictctl.llb. There are a couple examples about zooming.
Hope it helps
Alipio
"Qod natura non dat, Salmantica non praestat"
Message 2 of 10
(9,134 Views)
Image toolbox provide high quality image resize for Picture control.
http://www.geocities.com/gzou999/imgtool.htm
George Zou
George Zou
Message 3 of 10
(9,126 Views)
George,
I did download image toolbox and I do like it. Couple of questions:
1. What are licensing requirements for distributing vi's using the toolbox
2. I notice that the zooming always occurs with respect to the upper left corner of the picture. Is there anyway to make it zoom about a particular point in the picture. For example the user may want to zoom such that everything expands about the center of the picture
Jim
Message 4 of 10
(9,122 Views)
No license required for your client.
You may distribute your applications (exe, dll or VI/llb) with my VIs upto 1000 copies (each application).
If you want to distribute your application in VIs/llb with my VIs, you have to make your client aware that if they use my VIs in the project other than yours, there is a copyright issue.
Zooming point is just a redraw issue. For example, if you want zoom about the cursor point,
and the cursor is at (10, 10), assume the top-left corner is (0, 0), and your picture size
is 20x20, after zooming, you want to draw your picture starting at (-10,-10).
George Zou
http://gtoolbox.yeah.net
George Zou
Message 5 of 10
(9,112 Views)
Hi George,
I saw this old issue on the forum and it looks like your Image toolbox is exactly what I need.
It's been a long time. Can I still download this toolbox ? (where ?)
Thanks in advance.
Message 6 of 10
(8,519 Views)
The new address is:
http://webspace.webring.com/people/og/gtoolbox
By the way, this is a very old thread.  Latest LabVIEW already has a zoom function build-in for Picture control.
Depend on what version you're using, some version doesn't work well when shrink.  And not friendly with 32 bit image.
George Zou
George Zou
Message 7 of 10
(8,473 Views)
OK,
Thank you for that.
BR,
Mentos
Message 8 of 10
(8,428 Views)
Hi George,
I need to scale a jpg picture like the one attached to about 10 percent of its original size.
Before I purchase the Image toolbox (in order to use only the resize vi) I have to be sure the resulting picture is sharp enough to print (on a lable) and I don't get pictures like the "bad one" attached.
Is there anyway to garentee this ? can you send me some kind of demo etc. ?...
Message 9 of 10
(8,399 Views)
It would be looks like the one on the right.
George Zou
http://webspace.webring.com/people/og/gtoolbox/
George Zou
Message 10 of 10
(8,383 Views)
