Efficient way to select signals from dynamic data
Is there a more efficient way to select certain signal combinations from dynamic data than splitting all signals and checking them with a case statement and then merging the signals back up?
The "Select Signals" express vi from the signal manipulation palette seem to works, but it is only good for a predefined set of signals. I want the user to be able to show easily what signals they want.
Thanks for any comments or suggestions.
(3,384 Views)
Accepted by topic author Yun2
The Select Signals Express VI has a "Selector Input" where you can wire what you want to select programmatically. Take a look at the "Select Signals" example that ships with LabVIEW.
(3,362 Views)
Thanks for suggesting the examples. I will be sure to look there in addition to the help section.
(3,321 Views)
