zero fill string
I am converting a decimal string into the binary equivalent using the format into string function, just wondering if there is a way to left zero fill the results?  For example I have  5 converted to 1001 but would like to have the output string as 00001001, thanks.
(4,277 Views)
After the part you have accomplished (5 -> 1001), measure the length of the converted string and concatenate the desired number of zero characters at the beginning of the string.
Lynn
(4,271 Views)
Accepted by topic author svt4cobra6
format string
%08b
Ben
(4,266 Views)
thanks for the replies, changing the format specifier worked.
(4,261 Views)
You wil use format into string function with format string "%08b". The zero tells to pad with zeros on left. The eight tells the number of digits and b convert to binay.
(4,260 Views)
Good.
BTW
5 ===> 101
9 ===> 1001
now Ifeel better. Smiley Wink
Ben
(4,256 Views)
yep thanks for the correction on the binary math!
(4,242 Views)
