xy graph cutting data
I don't believe there's any signal conditioning between the two...I am hooking up the NI9215 with the same two BNC connectors that I connect to my scope. I put a bridge wire from the AI1- to the com port. I'm still getting the same signal.
Message 11 of 36
(3,123 Views)
How is your scope channel configured? 1 Mohm input impedance? AC or DC coupled? What is the model number of your accelerometer/driver?
Message 12 of 36
(3,095 Views)
The O-scope II is a DOS based scope. It's using 1 Mohm input impedance, set to AC coupled. The accelerometer is a Columbia 3030 with a 4102M charge amp.
http://www.atcweb.com/oscope.htm the scope specs
Message 13 of 36
(3,082 Views)
I guess that means I need to get a 1mohm resistor for my 9215?
Message 14 of 36
(3,076 Views)
Would it be possible to switch your scope to DC coupled and post a screenshot of the measurement? I'm curious what a "good" signal looks like, including any offset.
Message 15 of 36
(3,049 Views)
Changing the coupling on the screen doens't seem to do anything but here's the signal 12745501_10208737294338399_6032241408390357073_n.jpg
Message 16 of 36
(3,041 Views)
could you send data in file for analyse
Message 17 of 36
(3,020 Views)
Here's the data from the 9215. I attached my vi for reference.
Message 18 of 36
(2,983 Views)
hi,
I agree with @mateh, this has nothing to do with the XY Graph, but is rather an intrinsic error within the data.
Message 19 of 36
(2,944 Views)
How do I go about troubleshooting this? I'm stuck at this point in my development...
Message 20 of 36
(2,925 Views)
