xy chart buffer diversi colori
Salve a tutti. Sono un principiante di Labview, ma sto pian piano facendo pratica. Sto tentando senza successo di manipolare la "xy chart buffer" in modo da avere colori diversi per ogni run di acquisizioni che faccio con un picoamperometro. Ho provato diverse soluzioni ma ogni run resetta le impostazioni dei plot successivi al primo, riportando tutti i grafici allo stesso colore-settaggio. Qualcuno ha suggerimenti utili al mio problema?  Vi ringrazio per l'interessamento!
(2,747 Views)
English Translation (thanks to Google)
Hello everyone.
I am a beginner of Labview, but I'm slowly learning.
I'm unsuccessfull to manipulate the "xy chart buffer" to have different colors for each run of acquisitions with a pico-ampmeter. I tried different solutions but every run resets the settings of the plot after the first, bringing all charts to the same colour-setting.
Does someone have useful suggestions to my problem?
Thank you for your interest!
(2,744 Views)
Ops!! I'm sorry. I put the italian message in wrong section.
Thank you for your help JoeLabView  Smiley Happy
(2,737 Views)
Hello Kindom,
I figure that you want to retrieve plot informations (colour, labels, etc...) every time you run your VI. In this case i suggest you to look at the write configuration file functions and examples available under the "File Input and Output" section of the LabVIEW NI Example Finder. You can refer to this link  to get started. Anyway could you post your code so i try to understand what don't work fine in your application.
Best regards
Matteo
(2,695 Views)
