‎09-16-2010 01:39 AM
Hi all,
I need to publish a front panel which developed using xcontrol facade vi. The success factor is that iam able to access that in the web.
But the problem is that, the frontpanel not looks as similar in the application. The facade vi controls are getting misalignment.
What is the problem..Any Idea..Please...
‎09-18-2010 02:37 AM
No way to solve this issue? :mansad:
‎09-18-2010 05:51 AM
If you can able to edit the front panel that you want to access through net then group them all and lock it then try accessing it.. just a try..
‎09-20-2010 02:00 AM
Hi, anand thank for the reply, but i am loading the controls dynamically in a subpanel using VI server ..
