05-27-2015 10:35 AM
I Try to grap it but nothing apper in the graphic but dont know why 😞 can anny help me
voltaje 100
05-27-2015 10:50 AM
That plot function takes SGL instead of DBL. Change the representation of your inputs to SGL and it should work as long as you don't end up with values in V which are not representable as SGL.
On my first try I ended up with some +Infs in V which caused the plot to not show up either. When I fixed the range, the scatter points showed up correctly.
05-27-2015 10:59 AM
how i can change it to sgl , and when u say fixed the range hmm im confiused can u show me a image pls 🙂
05-27-2015 11:08 AM
It worked just fine for me. Note that you have to run the VI in order to create a populated "grabbable" image. As the previous reply noted, the Plot Helper expects SGL inputs, but it has no trouble coercing the DBL values into a plot (the coercion explains the red dots on the Plot Helper inputs).
Bob Schor (running LabVIEW 2014, 32-bit on 64-bit Windows 7)
05-27-2015 11:10 AM - edited 05-27-2015 11:11 AM
its worked to you show me pls .... Hmmmmm what happen its all fine ?
I Use labview 2013 32 bits in windows 7 of 64 Bits
05-27-2015 11:15 AM
hmm i see the version of labview dont give me the support to this graphic
05-27-2015 11:26 AM
I also tried it in LabVIEW 2013, also had no problem rotating the figure (after it was made).
BS
