writing data in spreadsheet
Dear all,
I am trying to extract frequencies by using Extract Multiple Tone Information. However, I am facing problem save the frequencies, amplitude and phase in the file. give me an error These cannot be wired together because their data types (numeric, string, array, cluster, etc.) do not match. Show the Context Help window to see what data type is required. The type of the source is Queue Refnum. The type of the sink is Dynamic Data.)
I have attached the file. Could you please help at this point.
Khalid
(3,259 Views)
First of all, you wired the queue reference into the Signals input.  That isn't going to work.
Secondly, I think you are going to have to change your array of clusters into a 2D array in order for it to be able to be written to your file.
(3,254 Views)
Hi Crossrulz,
Thank so much for your reply. however, where I should wire the queue reference?
How I change the cluster into a 2D. I want to extract the amplitude, frequency and phase and write into the file?
Khalid
(3,235 Views)
You don't need to wire the queue reference anywhere.
What you need to do is use the Element output of the Dequeue Element function to get the data out of the queue.
(3,213 Views)
Accepted by topic author engkhalid
To crate 2D array of amplitude, frequency and phase you need to unbudle the cluster by its name and build these elements into build array functions. For your reference  I have made sort of thing in your code. You may see the attachment.
CLAD
Passionate for LabVIEW
(3,190 Views)
Thank you (all) so much for your help. it is working properly. I can save data in spreadsheet.
(3,131 Views)
