Dear vcb,
First of all, let me welcome you to the NI forums. I am looking forward to work with you on solving the issue.
For the first step I recommend you to read this KB about the specific error code, it may help:
Why Do I Get Error 89137 "Specified route cannot be satisfied..." When Routing PFI Lines Over RTSI?
http://digital.ni.com/public.nsf/allkb/A7A4024278353BF7862570230072C6E1
It is also important to note that the routing in your case is 10MhzRefClock to RTSI0, (it is not wired to Sample Clock in your VI).
You could also check the DAQmx Device Configuration palette, where you can use an API to route within the device. It is generally adviced to do RTSI signal sharing in the following way:
Use DAQmx Export Signal.vi and/or DAQmx Export Signal Property Node
There you have a property for TimeBase sharing. In the other device, if you wire a constant to you TimeBaseSrc, you can right click the constant -> I/O Name Filtering.. --> Include Advanced Terminals
This way you get access to more options. From there you can specify RTSI0 as TimeBase.
Please let me know if you found these information useful, and/or if you need more help with the issue.
Peter
Peter L.
National Instruments Hungary
