writing Binary data
Hi
I am trying to write a binary data file in single precision format. Writing the data is not a problem, but when I read the binary file, the data seems to have one extra zero at the start of the data. the data seems to shift towards right. Labview is introducing a zero point s at the start of the file which is making that shift. How to get rid of that extra point when I am writing the data. I am attaching the program I made to write the binary data file (write binary data) and also the file (file.zip)which I am trying to analyze. Also attaching the program to read the binary file.
Message 1 of 9
(4,201 Views)
Works fine for me. I don't get the extra zero when reading the file.
Message Edited by altenbach on 01-19-2006 10:44 AM
Message 2 of 9
(4,195 Views)
Sorry, I see the problem now.
You are talking about the binary file 1.spn.
You are writing it as a cluster, but read it as a SGL array. You need to write it as a SGL array to keep the universe in balance. 🙂
Here's ther relevant modification:
Message Edited by altenbach on 01-19-2006 10:55 AM
Message 3 of 9
(4,189 Views)
I tried that way, writing it the way u said, but when I am reading it, it gave me some unexpected results. I want the data in SGL format and as the write binary file.vi uses 8 byte little indian format, when reading it thru the Read SGL data vi I am not able to read it properly.
thanks
Nitin
Message 4 of 9
(4,170 Views)
Of course data types for write and read should match. The function as in altenbachs picture will write doubles to the file. Just put a "To Single Precision" conversion node right after the log function and everything should be fine.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 5 of 9
(4,164 Views)
Hi Rolf,
I tried that and still it is not working. I am attaching the two wave form graphs which I am getting. The first one is the one which I am reading which is one point off and the second is the one which it is supposed to write. There is a just one point difference in the two graphs.
Message 6 of 9
(4,152 Views)
Hi Rolf,
Nitin
Message 7 of 9
(4,153 Views)
OK, I found the problem. You need to wire a FALSE to the "prepend array size" input of the write operation.
Message Edited by altenbach on 01-19-2006 01:55 PM
Message 8 of 9
(4,140 Views)
Thank you very much for that information.
I was trying everything for that, and that was just a small problem and I wouldn't be able to figure that out. Thank you very much
Nitin
Message 9 of 9
(4,124 Views)
