write to spreadsheet Help
Hello, I am trying to use write to spreadsheet file.vi to store my energy measurement data to an excel file. When I open the file after it saves data it comes out in a row instead in a column which will make my life much easier. I also tried to put shift register on this for loop it will save the data in the file for all the measurements instead of reseting to only new data, but it gives me errors about connecting two different data types. Any help will be greatly appreciated.
(3,411 Views)
What if you would transpose?
While evaluating my code please have in mind that I am a LV novice. Therefore sometimes my code might violate some coding rules that I have to learn about myself. But how else could I do that... 🙂
Chart zoom with "Mouse Over" effect
(3,408 Views)
Never looked at that!!!!!!Transpose takes care of the column problem. Thanks a lot Giedrius.S!!! Any ideas about the shift registers probelm???
(3,388 Views)
Accepted by JayP
I don't see any shift registers in your program, so I don't know about that problem.
But perhaps you want to wire a True to the Append Data? input so it doesn't overwrite old data?
(3,375 Views)
As you can probably tell I am new to labview.I have taken basic courses though and that is why I always think of shift registers when trying to do something like this. I will wire a true to the append Data and see if that eliminates the need of the shift registers. Greatly appreciate your help!!!
(3,365 Views)
I wired a true to the Append Data and that eliminates the need of shift registers I was thinking about. Thanks again.
(3,319 Views)
