write to measurement file - Create or replace with confirmation
The question probably is too basic, as I'm very new to LabVIEW. Basically, I tried to use "Open/Create/Replace File" to set my file path, but it doesn't have an output file path to wire into the "Write to measurement file express vi". I'm wondering if there is any way to make a file path with "create or replace with confirmation" settings (without creating an actual file yet), and then use that as the file path for the "Write to measurement file express vi".
Message 11 of 28
(1,806 Views)
Surely there is a better way, but here is what you can do based on your question.  It seems redundant, but modify as needed.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 12 of 28
(1,792 Views)
@SuSto wrote:
Is there a way to combine the "write to measurement file express vi" with the "open/create/replace file" function? Or, more basically, is there a way to wire any file path through another function and into the "write to measurement" vi?
Any Express VI can be converted to a regular VI by right-clicking on it and selecting "Open Front Panel". Yeah, I know, not very intuitive. You'll get a warning about it. Once you acknowledge you'll get a new VI which is a shell around another subVI, which is the actual meat of the Express VI. You can then modify the new VIs. When I do this I typically toss out the first-level VI since it's just a wrapper.
There's a Refnum to Path function in the File I/O -> Advanced palette.   EDIT: I see that Mo already provided the answer while I was entering my reply.
Message 13 of 28
(1,790 Views)
hi i am trying to append the data files in binary tdms using write to measurement file but its appending on right side but i want to append it on bottom is it possible
Thanks in advance
Message 14 of 28
(1,742 Views)
Set File Position function on Adv File Func pallete.
Message 15 of 28
(1,738 Views)
i have already tried this its appending the same manner please see my code
Message 16 of 28
(1,723 Views)
Message 17 of 28
(1,723 Views)
I assume you mean you want another channel of data. If so, just merge the new signal with your other one. Use the Merge Signals on the Signal Manipulation palette. The two signals will be written as two channels in your measurement file.
Message 18 of 28
(1,717 Views)
Hi thank you for your reply but i dont want to merge i need to append the datas its appending but its appending on right side i want to append next below of that previous datas  is it possible
Thank you for your time consideration and forthcoming response
Message 19 of 28
(1,711 Views)
Message 20 of 28
(1,711 Views)
