How can superimpose buttons over an image?
Hello to all. I have a little problem with my program in the front panel. I inserted a tab control and I wanted to insert all I had inside it. The problem is that I had an image below a set of buttons and at the time I migrate all to the tab control, the image superimpose to the buttons, how can I avoid it? Thank you 🙂
Carlos Ignacio Sarmiento
Electronic Engineer
(Ciudad Madero Technological Institute)
Laboratory of Bioelectronics, Biohospital Engineering Departament
National Institute of Neurology and Neurosurgery "Manuel Velasco Suárez" (Mexico City)
(2,950 Views)
Pick the image.  Use the Reorder button on the toolbar and pick "Move to Back".  The shortcut for it is Ctrl-Shift-J.
(2,947 Views)
Hi
select your image, and press Ctl+Shift+J. or, you can do as shown in the image attaced. move your picture behind the controls.
Regards
Freelance_LV
TestAutomation Consultant
(2,946 Views)
thank you folks, it's done now!! 🙂
Electronic Engineer
(2,943 Views)
