write in wave file
Hallo,
I'd like to save a time signal or an array as a wave file. It exists a write to wave file block in the funktion sound but I can't connect it the way that there is no failure message. Smiley Sad
Can somebody help me?
thanks!
(2,583 Views)
Smiley WinkI found the answer myself. It works, but first I copied the path instead of taking it from the frontpannel. probably I have copied some information that didn't fit in my program. Normally there's no problem using this block...
(2,576 Views)
