Help - Edit cell of a multicolumn listbox at run time
Hi All,
I am populating rows and columns of a multicolumn listbox from a file at run time. However, after the data is loaded in the listbox I want to have the option of changing cell value.
Can I do that? If so, how?
I appreciate your time and help.
Mim
(3,505 Views)
You have to use the property item names witch is a 2D string array.
Then replace the elements you want to change in that array and write it back to the table.
Check attachment.
Hope it helps,
Paulo
(3,499 Views)
Hi Paulo,
Thanks for replying.
I am on version 7.0 Express. Would it be possible for you to attach version 7.0 VI?
Mim
(3,494 Views)
Here it is.
Paulo
(3,486 Views)
Hi Paulo,
Many thanks for your help.
Mim
(3,475 Views)
