write frame memory leak
Every time I save an avi file, it keeps getting into memory and the computer stops later.
I would appreciate it if you could tell me why this is happening and how to fix it.
Message 1 of 10
(4,809 Views)
-If you are stopping the code by pressing abort button it is not good practice, have a stop button to control the loop.
-The only buffer you are creating is getting disposed properly so i don't see any leak.
-How did you verify the memory leak?
-What is your camera resolution? fps?
-Can you give more info on when the computer stops? After 30 min or 1 hr or 4hr?
uday
Message 2 of 10
(4,754 Views)
Thank you for answer.
The source is a vi made to check memory increase when saving avi.
I checked the memory leak by opening Task Manager and checking for LabVIEW memory growth.
Currently 10 fps.
The stopping time is approximately 25 days.
Message 3 of 10
(4,735 Views)
-Is this same VI which caused memory leak or is it stripped version of some other vi?
-Does it give any error/warning before your PC stops?
uday
Message 4 of 10
(4,728 Views)
Vi is same
This is where memory leaks occur in the project.
It just stops without warning.
In the Task Manager, LabVIEW memory increases slightly.
It continues to accumulate and eventually the computer seems to stop.
Message 5 of 10
(4,714 Views)
Accepted by topic author RevolutionKwon
25 days is a particularly suspicious stopping time.
If you have some kind of event that occurs once per millisecond and increments an I32 variable, that I32 variable hits its max value in 24.85 days.
I don't have the vision toolkit installed to check what goes on under the hood, so I don't know what that could be.  But that's what I would look for... an I32 that increments by the millisecond.
Message 6 of 10
(4,708 Views)
It's a problem that it's been on for 25 days.
But my client wants to stay on.
Is there a way?
Message 7 of 10
(4,699 Views)
-You haven't provided Camera resolution?
-Will it be running 24x7? (Acquiring and saving?)
-Please calculate the size of file for 5 sec and accumulate for 25 days.
-The files you are saving to C: drive in client machine? Check if disk is getting full.
uday
Message 8 of 10
(4,697 Views)
Sometimes I need to talk to the customer about restarting the computer.
Message 9 of 10
(4,674 Views)
Message 10 of 10
(4,682 Views)
