Write data to TDMS file using Picoscope 4824 example VI
Hi all,
I am fairly new to LabVIEW and trying to acquire data using a Picoscope 4824 and LabVIEW. I have downloaded an example VI provided by Pico technology - http://PicoScope4000aExampleStreaming.vi, as found here https://github.com/picotech/picosdk-ni-labview-examples/tree/master/ps4000a/64-bit-examples. The block diagram is attached as a photo.
I would like to build in a function that writes the data to a tdms file continuously until I stop the capture. Could anyone help out with where I need to place the function within the block diagram?
Thanks a lot.
(3,157 Views)
I would put it into a separate loop and pass data to that loop using a queue or similar mechanism. It is called a producer-consumer design pattern.
https://www.ni.com/en/support/documentation/supplemental/21/producer-consumer-architecture-in-labvie...
see also:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1r9CAA&l=en-US
(3,123 Views)
