write data to a logbook file only when a boolean indicator changes
Hello
I need to write my local variable state to a simple txt file only when it's true or false state changes.
for example, when my local variable 'temperature too high' is true, I need something like: temperature too high.
When it changes back to false i need: temperature OK. This with a date stamp.
It already worked to get a date stamp and to write the true or false state down but it always gets stuck in a while loop so the program keeps writing the same sentence.
(4,319 Views)
Post your code so we can do more than guess at what the problem might be.  Smiley Wink
(4,317 Views)
I had to take a picture with my phone because we're not allowed to connect the computers with an usb drive, I hope you can see it clear.
I know this while loop causes the program to write the same sentence over and over again but I don't know an other way to do it right.
(4,310 Views)
Accepted by topic author Tom_Pa
Hi Tom,
pseudocode:
IF current boolean state <> previous boolean state THEN
   save data to file
ENDIF
To check boolean state changes you can use the BooleanCrossing-PtByPt function…
(4,278 Views)
That makes life a little easier. Smiley Wink  I did not know that was there.  I guess I need to get out and look around more.
(4,263 Views)
(4,256 Views)
