would like a case structure with no o/p in false state
I'm sending data from a case structure to a graph but i only want the values that are generated in the true state to be sent to the graph. I was using the default value from the tunnel in the false state but this leaves me with unnecessary values going to the graph. Is there a way in which i can not send any values during the false state?
(2,759 Views)
Use a shift register and wire the value from it straight thru the false case. see labview examples for using shift registers.
Joe.
"NOTHING IS EVER EASY"
(2,752 Views)
Another way is to simply put the graph inside the true case statement.
(2,751 Views)
Sometimes i try to think to hard.
Joe.
(2,746 Views)
