word edit cell
Hi all,
I create a vi that inserts in a word template table values .
This work's fine but the table have 4 columns and if i update less than 4 column (example 3) the other is filled with the last column inserted (the last column is replied in the remains column).
I attach the code created.
Another question is why, also if i add an 2d array in the table, if i don't repeat the insertion for each column (for loop) the only column recorded is the first?
I attach the part of code
Bytelabs.it
(2,451 Views)
These are expected behaviors. I suggest you to implement an high level API that do what you are planning to do.
Enrico
(2,359 Views)
