Running cDAQ devices in Labview 8.0
Can you run cDAQ devices in Labview 8.0 using the latest DAQmx version supported by Labview 8.0? I purchased a cDAQ-9174 and some modules but the driver disk included (DAQmx 9.5) is not supported in LV 8.0. Is it possible to install the drivers without installing DAQmx 9.5 so that I can use the DAQ assistant with DAQmx 8.X? Thank you.
(2,652 Views)
Accepted by topic author DonaldKM
According to this list, the minimum LabVIEW version for the 9174 is 8.2.1, and the minimum DAQmx version is 9.0.2. I expect the former of those two to be the main issue here.
CLA
(2,631 Views)
Thanks for the reply. I guess no option but to upgrade.
(2,616 Views)
