wireless signal from arduino to labview(HELP)
Hello! How do I send incoming signal from the arduino to labview wirelessly? Thank you!
(3,341 Views)
Hi lamela,
when you need it "wireless" you could use WLAN…
Does your Arduino support WLAN? Does your PC support WLAN?
(3,331 Views)
Thanks for your reply!
Yes! How do I send signal from the arduino to labview? I have arduino connected WiFi with my PC and I'm only able to send values(TCP/IP)... but how do I send signal? I went google and saw tutorials using Init and Arduino Read Pin/Port but I was told it is not for wireless?
(3,285 Views)
Hi lamela,
about Arduino-specific questions you should read manuals of the Arduino IDE.
Or do you use a LabVIEW-Arduino API like LIFA/LINX? AFAIK they need wire-based connections between PC and Arduino…
(3,236 Views)
