wire appearance is different outside frames
I know I should know this, but I don't.  Smiley Embarassed
In my code, wires from cotrols to case frames, Loop frames or any frames are sometimes have a different appearance than inside the frame. The wire seems to have a very thin wire wrapped around it...
If amyone knows why plese, tell me! See the attached exmple.
Scientia est potentia!
Message 1 of 8
(4,374 Views)
Hi magyar,
this is very basic LabVIEW knowledge: wires show their datatype by color and thickness. The thicker the wire, the more dimensions of the array.
And another very basic LabVIEW knowledge: all this is easily found by reading what the context help window tells you about the wire(s)…
And even more very basic LabVIEW knowledge: the appearance of a tunnel at those structure borders tells you about it's behaviour!
When you don't remember those 3 very basic things you should (re)take the free online LabVIEW beginner resources offered by NI on their website! 😄
Message 2 of 8
(4,365 Views)
Thanks for the fast reply. What you wrote I do know. But that is not wat i was asking. Please look at the attached image.
On the left the boolean is a straight lile with a sinusoid superimposed on it. On the right, It is just a straight line.
Why?
Message 3 of 8
(4,351 Views)
forgot the image..
Message 4 of 8
(4,341 Views)
Accepted by magyar
That "shadow" (or sine) around the wire indicates constant folding. You can switch the display of constant folding on or off in the options.
Message 5 of 8
(4,339 Views)
Thanks!
I recently, for the very first time, I turned on constant folding.
Smiley Happy
Message 6 of 8
(4,324 Views)
Hi magyar,
the next time you want to show as images with fine details you should NOT use JPG. Use PNG instead…
Message 7 of 8
(4,309 Views)
GerdW,
You are right.
I used the Windows Snipping Tool and by default it wants to save snip as jpg.
Thank you for your time.
Message 8 of 8
(4,274 Views)
