windows like file dialog
Hello all,
is there any possibility to create a real windows like file dialog with
LV6.1, where I can specify the file type via DropDown-ListBox.
I dont mean the custom pattern: Custom Pattern (*.bin, *.txt)
but: Text file *.txt
Binary file *.bin
Thanks in advance,
Marko
(2,929 Views)
This is possible, but unfortunately the API that does this takes a cluster
with string pointers to it.
Easiest way to deal with this is to make a wrapper... I'm working on a work
around, but haven't found the enough time jet.
Wiebe.
"Marko Aschoff" wrote in message
news:b4mqun$1vjgl6$1@ID-169652.news.dfncis.de...
> Hello all,
> Binary file *.bin
> Thanks in advance,
> Marko
(2,929 Views)
A work around is this;
Create a heap (HeapCreate)
Allocate memory for all strings (HeapAlloc)
Copy the strings in the heap (istrcpy)
Put the pointers (to the strings, in the heap) in the GetOpenFileNameA
cluster
Read the \00 seperated array of strings
Close the heap (HeapDestroy)
Wiebe.
"Wiebe@AIR" wrote in message
news:3e6efaa3$0$148$e4fe514c@dreader8.news.xs4all.nl...
> Hi,
work
> Regards,
> Wiebe.
> > Hello all,
> > Binary file *.bin
> > Thanks in advance,
> > Marko
(2,929 Views)
