window Close Box
Hi all,
I'm trying to figure out a way to monitor the active windows' close box.
Ultimately, I'd like to be able to query the user to confirm the close
command before closing the FP. I know this can be done. I've found VI's
that do this type of thing, but unfortunately the diagrams are password
protected. Any help or guidance would be appreciated.
Denis
Message 1 of 12
(7,429 Views)
I'm searching the same kind of thing...
Did you find something?
FakStory
Message 2 of 12
(7,242 Views)
Not much point in posting to a 7 year old thread.Smiley Wink
This is pretty simple with the event structure. There's even a couple of shipping examples you should look at. Look at Event Conditional Stop and Event Tracking.
Message 3 of 12
(7,237 Views)
use an event structure with the Panel Close? event.  Set the disregard as true, and handle it anyway you like.
Message Edited by Stradis on 09-20-2007 10:07 AM
Paul
Message 4 of 12
(7,238 Views)
So dummie I am... Certainly...I was just focusing on an old password protected VI...
Thanks...
By the way, the icon to close VI, close all VI in operation, Right? even if it is not related...
Do you know if Labview have an icon for the close FP without property node...I mean 1 icon instead 4 or 5 icon and property node...?
Fak
Message 5 of 12
(7,230 Views)
Once you wire the method for FP.close, you can delete everything but the method.  So it looks like this.
Nothing else needed... One node, thats it... nice and tidy
Message Edited by Stradis on 09-20-2007 10:42 AM
Paul
Message 6 of 12
(7,227 Views)
great
thanks
Message 7 of 12
(7,218 Views)
You could also just invert the output of the yes/no message and wire that to the discard terminal. This way, if the user clicks yes, the close will not be discarded and the panel will close normally.
Message 8 of 12
(7,206 Views)
Where did you get the methode for FP ?
I didn't find it...
Message 9 of 12
(7,144 Views)
Sorry, I didn't wire the path to my open reference...Sorry...Thanks for the tip...!
Fakstory
Message 10 of 12
(7,141 Views)
