10-23-2007 01:02 PM
10-24-2007 03:40 AM
10-24-2007 06:20 AM
Thanks but I am not talking about a graphics display, I don't care what font is used. I have a PCB which drives among other things a LCD module. I want to test this PCB in a test fixture by connecting up to a DAQ instead of the LCD module. I want to use the electronic signals that drive the LCD Module and display what the LCD would display on the screen using Labview. I am about 50% done writing it now. I will post it when I am done. Being the hack that I am I am sure that there is a better way but whatever works.
10-24-2007 07:37 PM
10-24-2007 09:09 PM - edited 10-24-2007 09:09 PM
I don't think is problem is how things appear on his front panel. (Though a display that graphically looks like a real LCD screen might be desirable). I think his problem is how to capture the various digital lines in hardware, and decode them to what they mean. Essentially decoding the protocol of those digital lines.
I can't help with this as I don't know the communication protocol and have never worked with LCD panels before. I don't know how the other control lines affect the display. I imagine if you are able to capture all 8 digital lines at once (I guess they behave like a parallel interface), the reading of the digital lines could occur as a port and be converted to a numeric value (does the LCD behave like an ASCII protocol?) Perhaps the other control lines could go into other digital ports and be treated as triggers for when to capture.
If you are already 50% done, it sounds like you are making pretty good progress. I wish you luck on the completion of your program.
Message Edited by Ravens Fan on 10-24-2007 10:15 PM
10-25-2007 01:37 AM
Yes you are correct. There are actualy 11 lines to decode. I will just keep hacking away till it works. I will post it when I am done and I am sure someone can tell me how to do it better.
Thanks, Reid
10-25-2007 07:31 AM
Reid,
Do you have a part # for the display you are trying to simulate?
10-25-2007 08:15 AM
reid,
do you have the code that you drive the display with (in LV 8 or earlier)?
10-25-2007 10:19 AM
10-25-2007 10:20 AM
