wildcard value in case statement
 How would I use a wildcard value in my case statement. I evaluate a string value of numbers and try to do this "1234***" but it doesn't work. "***" represents any 3 number.
Please advise.
dphan128
(4,292 Views)
You can use a range of values: 1234000..1234999. A case can also be set as Default, but I do not think that is what you want.
Lynn
(4,290 Views)
You could mark one of the cases as "Default", and that case will execute when no others match. If you want to explicitly run that case only if the first 4 numbers are "1234", then you need to pre-process the string.
See here for the same exact question.
(4,288 Views)
Thank you all, I think I'll pre-process the string before evaluate as you suggested.
dphan128
(4,252 Views)
